Hi Harry, I have Never used Hardibacker on walls. But I use Wedi or Marmox, on brick work I think flex adhesive would be better. Mapei or the like, not sure if Hardiebacker is suitable for dot and dab.
Thanks for all your replies and info, due to the bare brick work been very uneven ( 120 yr old house ) so a full bed of adhesive is not possible, i think I will have to dab it out with plasterboard and then fit a homelux tanking kit ..
you could use no more ply! you can dot and dab that. you just use spf adhesive and prime the board with sbr @ 3-1 ratio..they do 6mm and 9mm and you can use you 6mm for doting and dabbing
