silverbullit
Well firstly i would like to say greetings to all as i have not used this forum for ages. I have just had some work carried out in my home and it consisted of a bathroom refurbishment and a cloakroom toilet refurbishment, we had a brilliant plumber who did all of the studding out and boxing in and we had another guy who was a tiler to just supply labour for installing the tiles we had purchased.This job took us about six months to get to a stage where we commited to start the work , this was partially due to us locating the right people to do the job for us just how we wanted it to be also we were in no real rush. We went through all of the aspects that we felt needed to be discussed which covered the main important points, from the plumbing side of things it was where the bath goes and where we want the sink etc.... we had a similar conversation with the tiler, we stated that we wanted floor to ceiling tiles and that we were indecisive at that point as to how we were going to finish the corners( plastic trims or cut and angled corners as this was an option from the tiler at that point). We decided that we did not want plastic trims and let the tiler know a week before the job started, when he turned up he told us he could not cut the tiles as they had a slight bevel on the outer edge and his cutter would not do that.. so we were forced into the plastic trim route, so on the first day everything was going well as he laid in the underfloor heating and then tiled it all in , then on the second day he turned up with a school leaver to help him, with all due respect to the lad, he had no idear what the device that was in my garden was for.... this was a wet tile cutter !! so he showed the ;lad how to cut a tile and then he stayed indoors and had the lad runing back and fourth cutting tiles as they were needed ,i lost count of how many tiles the lad broke by pushing the tile too hard resulting in the blade stopping dead and snapping the tiles. So the tiler started on the walls and to the untrained eye was looking very impressive , but as time went by .... little details were beggingnig to not look right , he finished a boxed in section with plastic 12mm tile trim(that he carried on his van) and on the very corner he used no corner quadrants , he just cut the edge with a saw and left a 5mm sharp corner jutting out of the tile edge, then he left a 14mm gap between the ceiling and the tiles on the wall, this he filled with grout that is only qualified for 5mm max. there is areas where he has missed the grouting completely and left six inch horizontal gaps with no grout at ground level, the 14mm grout is now drying out and cracking, also an area of boxing in has yet to be tiled and he has not come back to do it ( and i get the feeling he probably wont as its not worth the time and trouble for him to come out and finish it fully). And the final issues are that he has not filled in the booklet with the test values of the underfloor heating tests , nor has he given us an invoice or a reciept as he has been paid in full allready !!!!
The only reason he wanted paying befrore it was finished was that the job was taking him longer than he had estimated and he had a new job to start on the following monday, we had to go away for the weekend and had to pay up by his insistance in full before we left, when we returned we were not very happy as it looks like it was rushed and he had not used all of the propor trims that he should have used to make the job look great. We also noticed that he did not use any P.V.A. on the painted walls prior to spreading glue on the walls and fitting tiles , he also never used the bottles of bond promotor that he should have used before strting to lay the underfloor heating, we still have them in the hallway!
Thje tiles were polished travertine and we got all of the correct Bal adhesives as per the store who supplied it, we had tow types of grout , one for big gaps and one for small , we also had all of the underfloor kit all sorted as we bought the best that we could find, all in all we stumped up well over 2.5K in materials alone.
We are now feeling like the guy had no real interest in doing a job correctly and this could result in early failure of adhesion of the underfloor heating ar the large travertie tiles.
This guy was not sourced through the forum but he was reccomended through checkatrade....
Any suggestions or do i have any angles to force him to cough up some of the money he has been paid to do the job as there is remedial work needed to sort out some the ugly bits.
Silverbullit:mad2:
Silverbullit:mad2:
