Hi Dave.
Thanks for the update, i do have trading
standards on my list of people to contact about this but at the moment i am getting as much info as i can so when i do make a move to sort this out i will be well advised and well armed beforehand. I think that you are quite right about the trims , we did decide to just have him cut the tiles with a mitered joint to avoid the plastic trims situation but he said it could not be done.... and after seeing the kid learning to cut tiles with our expensive travertine , it would have been a much worse disaster than the minor one i am dealing with now.
I would like to say that the wall that was stripped of ceramic tiles was just scraped back to the bare cement rendering , as far as i am aware there was no stabilising materials used on the cement prior to tile adhesive, as i am no expert tiler i am now not sure if what he did was correct or not.
I only found this little tit-bit out about the manufacturer of the trims but they dont make cove trims or corner trims so the plastic trim he carried on the van would have been more acceptable if he made the effort to locate the manufacturers who do make the cove and corner trims to match what he has done.... but as i have found out, this additional set of bits will cost me almost £100.00, then i have to butcher the anchor off the back of the cove as its designed to laid in with a tile to trap it in place , as he has laid the tiles without the trim... i have to adapt the back of the trims and bond them in with silicone.
This job could have been fantastic if only he never underestimated how long it would take to do and if he used all of the correct trims.... or better yet , just cut the tiles correctly himself as trims would not be needed at all.
Silverbullit
