JamesRB
Hi there, I have a problem that I keep on going over in my head and keep comig to different conclusions!
Went to have a look at a job and it is around 50sqm in slate 900x600, basically one big room. It is weyroc on joists and it has been glued and screwed with no deflection visable.
Now here is the problem, there are already some built in wardrobes and units and the joiner has only left in the region of 25-28mm (only quickly measured) under the doors that open. Therefore the tiles must come in uder that.
I recommended to him to overboard with 12mm ply then lay the electric ufh, mapei fibreplan then tile. I worked on 12mm+5mmslc +4mm addy and 10mm tile. Making 31mm and this is too much.
So i thought 6mm hardi but i don't think this is an option because of cost over the 50sqm.
I'm now thinking along the lines of not using the slc and tiling straight on to the ufh. theerefore saving some height. Suggested by local tile shop, but worry abot this creating future issues.
Also thought about using ditra in some way to isolate from the chipboard(very solid).
Whats the best option to come in under 28mm and keep cost resonable:mad2:
Any thoughts welcomed
