Hi all,
Thanks for your welcome, hoping someone can help!
Sorry in advance for my long winded post, am trying to give as much info as I can.
Just under two years ago we had our bathroom refitted. All the walls and the floor are tiled. (three internal, one external) The wall tiles are made by a firm called Vitra Karo and are 298mm x 598mm x 9mm
Initially I noticed some cracking in the tile surrounding the shower control within a few weeks of the install but wasn’t too concerned because these were only visible when water was sprayed directly on it when cleaning and I assumed it was a natural quality of the tile. Over time it has worsened as you can see in the photo.
Recently however I have noticed more and more cracks in the tiles on three of the four walls and I have attached more photos to illustrate.
These cracks travel in all directions, some to the edge of tiles or some just in the middle. Some have one crack across the whole tile, some have many cracks. Some of the cracks appear to be crazing in the surface of the tile whilst others are cracked right through enough to admit a piece of paper. Some are only visible when the tiles are wet (water darkens and also settles onto cracks making them obvious) but these seem to worsen and become more visible over time.
I have found only one place where the crack extends into the grout so I think this
rules out subsidence, the bathroom was tiled on two of the walls before with no issues anyway and we can see no evidence at all of any subsidence. Visually I can see at least 20 of the tiles are cracked and these can also be felt with a finger nail. When I wet the tiles I can see cracking on at least 30 more.
My first reaction was there must be a fault with the tiles however I no longer think this is the case because on one internal wall there appear to be no cracks what so ever, the same is true of a constructed bath side which is also tiled.
What could be causing this?
I realise it may not be possible to “diagnose” the problem over the internet so how do I find an expert who could come and examine and report on the tiles for me and suggest any possible solution? How much could I expect to pay for such an opinion? I live in the Lincoln area.
Many thanks for any help and advice you can offer.
Regards,
Rach
