Discuss Help aqua board has been skimmed in the UK Tiling Forum area at TilersForums.com.
JVC600
the plaster skim has come off in little pieces ..
very brittle
well i am going to get the rest of the plaster skim off these boards in next few days .
i will then tank over the boards with the bal wp1 kit i think .
that should sort the problem .
i know now gypsuim plaster skim and knauf aqua boards dont go together.
i think to elimante the aqua boards been been originally pva i will wash them off with water then give them a quick light sand with 180 grit sand paper before i tank them .
should be ok then ???
Ken Bruty
1,023
Bedford
I would still be concerned whether the boards are suitable to tile at all, because pva was used, and it's unlikely to have come off with the plaster, therefore, you still have a skin over the aquapanel which the tiles would be stuck to, and the bond is only as strong as the pva skin. Aquapanel should never be primed either, to be safe I would replace them completely imo:thumbsup: Also the dust from aquapanel is harmful, so I wouldn't recommend sanding that either.
JVC600
thanks for the replies .
i took a wall paper stripper to the boards last night .
the plaster just fell off afer about 10 seconds worth of steaming
have spoke to kanuf technical and bal reference tanking them .
they said as long as i can get the plaster off they should be fine .
as a safe guard a light sand with 180 grit should get the key grip back after washing them off with water .
as for taking them off they cost over £75.00 to replace so dont think i want to to do that .
tanking them will make them totaly water proof , so hence use the bal primer them the tanking kit .
i think this will do the job ??
Reply to Help aqua board has been skimmed in the UK Tiling Forum area at TilersForums.com
