Discuss Help please repairing floor in the Canada Tile Advice area at TilersForums.com.
Joshjupp
558
Maidstone
Or piped within the joists ??
Thats what I reckon pipe work in between the joists all sitting on top of insulation I looked at a big floor the other day and it was the same they are having wooden flooring instead of tiles now as I advised
Sorry for not being clear - I’m a novice
bottom up Joist, with celotex between and then aluminium trays with pipes for UFH then ply, then ditra and finally tile. The floor is one big kitchen dinner and is approx 65m2. There is also brick support in the floor for joist etc. Thanks everyone for your help.
Dumbo
So what you described should not fail if done properly . Ply should be fixed securely and all joints supported. So either falling on a joist or a noggin.
Ditra should be stuck securely with coverage completely under the matting, then when installing the tiles all mat cavities should be filled prior to creating a rib bed on top and then tiles should be back skimmed and fixed to ensure full coverage but all of that is no good if you can feel the floor moving prior to tiling .
Reply to Help please repairing floor in the Canada Tile Advice area at TilersForums.com
gamer1
Tonbridge
What member type are you?
  1. Homeowner
Business Name
Na
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
