Discuss Help Re-tiling bathroom floor in the Bathroom Tiling Advice area at TilersForums.com.
U
Unregistered
Hi all,
Reasonably new to the tiling game, and in need of advice. I've just had to pull up all my tiles on the bathroom floor because they had come loose. They were fitted about 18months year ago but not sure what adhesive was used. The floors chipboard with stapled 6mm ply done by the tiler. What are my best options? Here's what I've gathered so far:
1)Re-lay tiles using fastflex.
2)Re-lay tiles using rapidset flexible.
3)Rip up 6mm ply and replace with 6mm backerboard and use rapidset flexible.
4)Overlay 6mm backerboard ontop of ply and use rapidset flexible.(this option does give hieght issues).
The floor as is seems reasonably solid, but my main concerns are water contamination of floor as its a well used bathroom. Also the price of the tile adhesive, been quoted at £75 for 1 set of fastflex and £55 for bag of rapid flex - does this this sound about right, as most other brands (unibond etc) are about £15.
grumpygrouter
replace your ply,and screw at 200mm centres,prime the ply and use either Fast flex or rapid set flexi,personally i would opt for fastflex,but that price you have been quoted is about double what CTD charge me mate
You don't prime ply if using these adhesives. The back and edges must be sealed with SBR prior to laying.
stevewataz
good advice is to use a backer board.
Take up the ply as it is too thin and use a flexible adhesive appropriate to the type of tiles ie travertine or ceramic.
£75 is rediculous per bag BAL or Dunlop are very good.
AS an ulitimate solution you could just rip up the flooboards and replace them with 18mm marine ply.
Reply to Help Re-tiling bathroom floor in the Bathroom Tiling Advice area at TilersForums.com
    • Optimistic
My tiles are moving after 3 days of been layed on Cement floor. I used MapeGrip D2. just seen a...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Unsolved
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
