Russw77
hi can anyone give advice about tiling round a floor drain in a wetroom?
basicly the drain is like this.
1. a white drain body " 10 inch " in diameter with a bottle trap underneath which connects to the waste.
2. there is a sqaure metal grid which sits in a plastic cap. underneath the cap is a round lip which sits in the main body.
the main body has a lip which fits into the cap. but also around the lip there are little slits which look like the allow water to drain away, anything that dosent go down the grid.
my question is if i fit the cap (with the sqaure grid on it) to the main body and tile round it will the adhesive block the slits around the main body hole?
basicly do i just fit the grid and tile round it?
will i block the slits around the main drain hole with adhesive?:20:
