help wetroom drain best way to tile round it?
yes ive done the weber pre formed trays and impy decks both pre formed trays with traps built in. this is the first one like this ive done.
Ok..so you know to make sure the drain is water tight in the substrate....the rest will be simples...:thumbsup:
yes the ply wood floor dose fall to the drain. tommyzoom yes the way you describe it sounds the same drain. it clamps to the tanking/ply wood and has a plastic cap that pulls off. there are slits around the main trap to allow moisture to drain away.
drain is water tight. would you just fit the grid, tile round it and try to keep the moisture holes clean?😛rrr:
right then sounds like that is the way to go. yes its all tanked up and ready to tile just wasnt sure about these moisture slits in the trap. thankyou to all for replying.:hurray:
