Help with awkward-shaped bathroom
Minnie
Hello
Hoping to get some good advice here. I'm attempting to do my first ever tiling job, and now that I'm unemployed, on a tight budget so can't afford plasterers etc.
It's a council house just over 100 years old and it looks like the current tiles have been placed onto a concrete wall. There were three courses (not sure if that's the correct word for a layer!) of 15-15cm tiles. The top two I've got off with no problem and have managed to get the adhesive off easy enough, but it looks like the bottom layer of tiles have been laid onto something more concrete based. I'm not sure why and I'm not sure whether to hack this off or if it's covering up something bad.
That's the first problem. The second problem is there's a few funny angles. Some people have said I'm better of sticking with small tiles, whereas others have said to get big ones for the horizontal parts and cut them (obviously more wastage if I go wrong)
I've plenty of pictures if anyone's interested.
The tile size is not that big but you would need a cement based adhesive looking at the state of the walls, you may need to build up in certain areas.
To be fair, even a good tiler will have his work cut out for himself on those walls.
Do you have a friend/relative who could help you out
Go on, fill me with confidence!
Friends/relatives? Not any that do tiling.
Why do I need a cement based adhesive when the tiles that were stuck on above the first layer weren't stuck with cement based? I'm not questioning your judgement, I just want to know the difference.
Tubbed adhesive can be fixed with a 6mm notched trowel and have a bed of 3mm max and is air drying, so for the size of your tile would need a few weeks to dry properly.
Cement based adhesive, even a slow setting one cures by chemical reaction so would be more suitible for your size tile so grouting could applied the following day
Well I'm not necessarily going to use 25x33cm, I just figured it would be fewer tiles to lay, but then I have the problem of the horizontal surface.
Do you think every bit of wall is in a chronic condition or just certain ones?
Is the cement based adhesive to do with the size/weight of the tiles or because of the condition of the walls?
I know the one above the sink is bad. It looks like there were nails/screws in there at some point and someone's tried to fill the holes. I was thinking of putting a mirror there to disguise that certain bit of wall.
PS: Thanks for all responses so far
Under the circumstances this what could be helpfull;
Use a smaller tile, 6x6 or around that size then you use the tubbed adhesive.
Cement based is both in the curcumstance.
i would prime still where your going to tile because of any powder/dust.
Yes you may have to hide that certain area with a mirror.
You could use the remaining primer for the rest of the bathroom before you paint just to seal the surface.
A good box of filler to cover any cracks/faults in the walls.
Sand down then paint.:thumbsup:
Would it look silly to use 6in tiles on the horizontal and bigger tiles on the vertical?
Was planning on putting some primer on the whole wall as there's black mould on top of the paint. Didn't realise you put it underneath tiles though.
Have planned on filling in all the cracks and holes and then sanding. I know sanding's going to be a nightmare, and I know that an electric sander would cause a huge mess, but would it damage the walls? I'm not sure my wrists/shoulders are up to manual sanding.
bleach ain't gonna cure it Minnie (managed to open pics:hurray🙂 council have a "duty of care" and a "decent home" mandate to adhere to. Insist on a home visit with an Environmental Health Inspector, that black stuff aint gonna go away with bleach:thumbsdown:
