Discuss Help with tiling on board. in the UK Tiling Forum area at TilersForums.com.
E
easyt
I am shortly going to diy refit my bathroom. Bath is being removed and I am installing a 1700 * 800 shower. I have tiled 4 bathrooms before and also 4 kitchens. I have a number of questions but will ask in small doses.
I intend to create a stud wall off one of the walls using water resistant plaster board in the general area and aquapanel in the shower area.
The wall tiles are 260 by 300 ceramic.
1. Do I need to treat the aquapanel before tiling. What do you recommend.
2. Same question for the plasterboard. I have never tiled on plain plasterboard.
3. Would a ready mixed adhesive be suitable for this size tle on board.
More questions to follow.
Easy T
doug boardley
I very rarely use ready mixed adhesive. I'd use a standard setting single part flexible adhesive if I were you. I wouldn't bother with moisture resistant plasterboard as if you prime it, it will delay the setting time of your addy, just use normal 12.5mm plasterboard and prime with the appropriate primer for your addy. Your aquapanel won't need priming but you'll need to tape the joints with wterproof tanking tape.:thumbsup:
Reply to Help with tiling on board. in the UK Tiling Forum area at TilersForums.com
Hi, first timers here... I am tiling my bathrooms and prefer the look & neatness of tiling...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
