ollymonkeynuts
Hi, Im shortly about to dive in with both feet into my 20sqm travertine bathroom tiling project with the shower area being mosaic. Ive bought 22mm T&G chipboard flooring, a BAL 1 waterproofing kit, Tuff form shower tray, Devi underfloor heating mat and will be getting some Living heat insulation boards for underneath. Basically im nearly good to go. However im puzzled with the choice of sealant/impregnators out there. I know Aqua sealer gold choice 15 is the best but its well pricey and although HG is cheap its not as good as the lithofin stainstop stuff which sounds good value, but then theres the Bal protective sealer and the Fila protector!!?
Unfortunately im on a budget so with that in mind what do you guys (&gals?) think is best?
Thanks in advance, I suspect this will the first of many questions to come. Olly
