Discuss Homelux matting adhesive advice in the Canada Tile Advice area at TilersForums.com.
Dan 6457
Hi there,
I have been reading through this forum over the past few weeks, very helpful info on here. I just wanted to confirm that I have chosen the right products for my job.
I am fitting homelux waterproof matting to walls around my bath before tiling. One wall is brick which is rendered and skimmed with plaster, the other is a stud wall which is plasterboarded then also skimmed with plaster. I know ideally it would have backerboards and tile straght to that but I have to work with what I've got.
I have come to the conclusion that I need to prime the plaster with BAL SBR Bond, and then stick the matting up with BAL CTF4. Then stick the tiles up with CTF4 as well.
Have I got this right?
Cheers!
Reply to Homelux matting adhesive advice in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
    • Friendly
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
