bluevin123
Hi,
Still tiling a bathroom in 600x300 12mm thick copper honed slate tiles.
In the shower area I have put up some of the Homelux on a roll stuff on the two shower walls...Its only a metre high, I know some tanking kits say thats all that is needed, but do you think I should put another piece on top to make it 2mts high all around the two walls just to make sure?
Also the weight of the tiles will not pull it down from the wall, will it?
I have bedded it in nicely and it seems solid enough.
Hope you can help.
Cheers.
Vinnie.
Hope you can help.
Cheers.
Vinnie.
