How best to Tile a room?
So I put down some insulation boards earlier, it was keraquick s1 flexible adhesive 20kg mixed with 5.2 litres of water, I certainly learnt a few lessons today, I used a 6mm notched trial, and back buttered all boards, it was all a bit frantic, I believe I have kept about 5mm around the edges free from board but not free from adhesive, does this matter? Although I believe I was fairly consistent with the mix I can see one or 2 slight ridges, this time I was on my own and it was rapid set, for laying tiles I'd have someone with me, I wouldn't be using rapid set and id be using levellers inbetween the tiles, I've only put down 7 boards so far so I am hopeing by the time I've laid them all I'll be a lot better at it.
yep I will have a cleanup, and I've got the screws and washers so will put those on also.
I'm trying to work out how many levelling clips/wedges I will need for this job, I've got 42 800 x 800mm tiles to put down, which works out as 23.3ish square meters,
I'm looking at;
RLS leveling system & Tile Spacers - http://www.kwiksplit.co.uk/acatalog/copy_of_copy_of_Raimondi_Tile_Spacers_and_Levelling_System.html
but can't work out how many I need, doesn't help that the chart consumption chart doesn't open for me on my laptop.
I'm looking at;
8,7 pz for mq
Raimondi s.p.a. professional tile tools Raimondi Levelling System - Raimondi s.p.a. professional tile tools - http://tilelevelingsystem.raimondispa.com/
DIY Tiling Forum
mp3wizard,
Time's Ran Out,
mp3wizard,
Time's Ran Out,
