How can you tell what the quality of a tile is...?
Aspesim
Hi Guys
I've seen some ceramic tiles which I like in Topps Tiles however, Tile depot do a similar tile for about half the price... (Not the same dimensions but each one would cover approx the same sized area).
I've always been a firm believer in you get what you paid for... or in this case am I being stupid? Is there a differance in quality of tiles of the same thickness?
Or is it Topps Tiles just adding £ to their prices because they are a major retailer.
As experts and work with all kinds of tiles I wonder what your thoughts on this are:
Regards
Aspesim (aka DIYBlues - on plumbing and electrical forum).
Do you have the names of the tiles or links. Members of the forum may have used these tiles and give feedback.
I do know from 1st hand experience though that Topps have high prices mostly IMO. I recently got the exact same tile for half price elsewhere and it wasnt a one off offer.
Generally speaking, if the tile has a very red/brown clay on the back then it's usually of poor quality.
Ceramic tiles are generally all of the lesser quality tile types although they're still not bad to be fair. They just chip easier etc.
Thicker ones might often be 'tougher' than thinner ones but all will be prone to chipping if something heavy is dropped on them in the future.
As Sir Ramic said, link us to them both and we might be able to help you out.
Thanks for the info so far guys
They are both named Marfil Cream (I think). The one from Topps Tiles is approx 250 x 750mm.
Regards
Aspesim
Both are ceramic so doesn't make much difference from that point of view. Both fine for walls. Both look nice to me.
I'd go for whatever you think as they're very similar in quality and style IMO.
Ceramic is ceramic.
put tiles face to face see if they curl at the courners then push four tiles together see if they are square then look at thikness of glaze then drag your keys over the surface see if it leaves a mark carrey all these out should give you the anwser you are looking for
I want to add that the quality is depends on a material what used to make tile and not thickness of a tile.I am renovating my home with new tiles and I am using a ceramic tile of 4 mm. It is sufficiently thick. The cement used to make tile should be of good quality and the other material is also of good quality. But the thickness also keeps an equal importance like quality. The tile must be of sufficient thick. If you bought a tile of more thickness then when you place a tile on floor then the floor become a more highted. Also, would like to mention is there are same type of designs for two different qualities hence you need to check that all the tiles is of equal thickness and same quality.
Aspesim,
DavidCampbell,
Aspesim,
DavidCampbell,
