Discuss how do i baton on tanked walls in the UK Tiling Forum area at TilersForums.com.
Guy's... You should be aware that there are quite a few makes of bath that should be installed after the room has been tiled.....
Created on iPhone.....
Ok, but is is your point of view. For me working in new bath is a madness. I have crosses even in such a things like fitting the sink or loo and then tile around which is really ridicoules. It is not the same as wall and floor tiles, becouse in this case it is easier to cut floor tile and then cover it by bottom cut but you do not need to cut a bath. Bath is straight tile surface is flat as well it match and it is small bead of silicone, maybe wider than 2 mm but still very neat. It is all about to not work inside the bath and got same wide of bath edges which looks symmetrically. Do how you like to do but please do not try to convince my that my way is wrong. Bathrooms are usually small so i got even more work space all the time and then bath at the end all i need to do is a silicone.
hmm, well... Difficoulty for me, writing in this forum is that my english is not so good to express my emotions in kind and good way. I am not going to teach you which way, becosue i am not a teacher, i am still learnig and i am guest in this country, do not want to look like pighead. But honestly, for me tere is not another way to fit a bath then doing it after tiling. Did not want to be intrusive just defending my point of view as i see it reasonable and logic.
Tank the wall.
Let dry.
Fit bath tight to wall if it's not a free standing one.
Jump into the bath with bucket of adhesive and wave your hand to your custumer esspecially if bath is worth few grands.
Tile Walls.
Grout.
Job done.
Lol
What happens when you are fitting a bath into a corner and the corner is not at 90 degrees. If it runs out by 10mm do you just fill the gap with silicon?
Reply to how do i baton on tanked walls in the UK Tiling Forum area at TilersForums.com
