Discuss how do i baton on tanked walls in the UK Tiling Forum area at TilersForums.com.
Tbh we've always been taught to fit bath first mainly due to walls being out of sync. Sometimes you even find yourself putting part of the bath into the wall!
Probably a uk thing and were not disputing how it's done elsewhere or how reliable either method is.
Well in my 7 years here and my bosses 16 years here, never been bitten on the bum with that. But then again, when we build a wet room, it is just that, a wet room, entire floor mechanical membraned which also goes 15 cm up the wall with 4cm of screed on top of that with heating cables in the middle of it, all walls covered in wedi or similar, all joints membrane stripped, from what I gather an English wetroom is what we'd call a few wet spot areas in a room if just the wet areas are membraned, so even if our silicone along the bath did fail, it pretty much wouldn't matter a jot. Don't get me wrong, it's over the top here, but I just play by the rules and it puts food on my table so I just get on with it, I still don't see a problem with fitting a bath and overlapping the rim with tiles, but it's just not done like that here, madness.Tile wall
Fit bath
Book return appointment in 6 months to remove all water damaged areas due to seal failing.
Reply to how do i baton on tanked walls in the UK Tiling Forum area at TilersForums.com
