Discuss How long? in the British & UK Tiling Forum area at TilersForums.com.
JLM Tiling
Hi guys
I've been working on some external steps on and off over the past few weeks and have finally been caught out by the weather. I had used some render on the treads with sand and rapid cement but today I got caught out by some rain and it all got wet. Am I going to have to wait for it to be bone dry again before I can use tile adhesive on it?
JLM Tiling
Temperature is okay down here at the moment, been between 8-11 degrees for the best part of a week. That's was what stopped work for a bit last week when we had that cold snap and had to stop. I'm gonna explain that to the contracts manager. He's a sound bloke but thing is it is my fault. I didn't cover it up. And it's a black mark against my name with the company. Plus about ten subbies are not getting paid until its all done (long story) so basically I feel like a bit of a prat!!
jay
If you can make some sort of tent over the area you may be able to get some sort of blower going to try and dry them out quicker but it depends on the situation 'best to get them dry as if they are holding moisture that will stop the adh getting a bond
good luck
the old kero blowers were good
Reply to How long? in the British & UK Tiling Forum area at TilersForums.com
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
How long?
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
