Discuss how many use a gauge rod in the British & UK Tiling Forum area at TilersForums.com.
Aston
a tape measure works for me but there are times when a gauging stick is really useful when you have a few obstacles on one particular wall and the visual side of things does make more sense than the maths even though they work out the same if you get my drift.. 'a case of the view reveals more than the distance'...
Q
quackfly
i 'walk' a tile either along a wall or floor following the datum line, count the number of full tiles then when i come to the end of the wall and cant get a full tile in i move the tile forward according to how many grout lines there are and thats where the cut will be. Takes seconds. its not so easy on large format heavy suckers tho! like trying to walk a St Bernard!!:smilewinkgrin:
Stephen@Weber
I think a gauge rod lets you mess around with your starting position more and makes it quicker to decide full tile half tile start from the centre etc Also mirroring your cuts and if you have a lot of obstriuctions it makes it very easy to check.
Sometimes moving your start position 5mm will make a big difference with the look and how easy it is to tile.
Reply to how many use a gauge rod in the British & UK Tiling Forum area at TilersForums.com
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
Edd The Tiler
E
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
hi, i am a virtually retired tiler (58), legs back hips etc etc. a friend carpenter (65) has...
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
