how many use a gauge rod
i marked one up for my kitchen so i could see what was going to look best as i have a window and extractor on 1 wall , helped me a treat :thumbsup:
I use both , it really depends on the tile and the layout.
The stick is much quicker and accurate on big walls
everbody is differant tho, some ppl like to grid, use spacers and whatnot
i 'walk' a tile either along a wall or floor following the datum line, count the number of full tiles then when i come to the end of the wall and cant get a full tile in i move the tile forward according to how many grout lines there are and thats where the cut will be. Takes seconds. its not so easy on large format heavy suckers tho! like trying to walk a St Bernard!!:smilewinkgrin:
I think a gauge rod lets you mess around with your starting position more and makes it quicker to decide full tile half tile start from the centre etc Also mirroring your cuts and if you have a lot of obstriuctions it makes it very easy to check.
Sometimes moving your start position 5mm will make a big difference with the look and how easy it is to tile.
Always tape and a calculator ........I was taught you should never have a tile cut less than half the tile you are using so simple.
Always use a tape, mark a centre/certain point and walk the tile along the wall/floor. Awkward at the start but becomes second nature. Staff does have it's uses though.
