Discuss how much addy in the British & UK Tiling Forum area at TilersForums.com.
doug boardley
if the floor is flat, or you are self leveling afterwards...
durabase can be laid with the smallest trowel you have (3mm?)
and you can do a wet mix.. i would get 10 - 12m2 out of 20kg.
going to look at it tomorrow dagger, I know some of the guys on the project and theyre top notch guys, so hopefully the floor will be nice and flat, altho not sure what substrate is yet:thumbsup:
dagger
as you know doug, substrate changes some of the rules! but a decoupler on an even surface (concrete or ply) can still be laid (and should!) with the smallest trowel you have, i use a 3mmx3mm square notch for laying decoupler...its like mosaic fixing, the addy goes for miles!
personally i use a wet mix of keraquick grey...
Reply to how much addy in the British & UK Tiling Forum area at TilersForums.com
got an 80m2 porcelain job upcoming ....seagrass carpet currently down on top of foam backed...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
how much addy
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
