Discuss how to build a bath panel in the UK Tiling Forum area at TilersForums.com.
Perry
what i mean is pj that you have created a removable peice of board ther as well that come off
i dont do that i leave the board fixed and cut a hole which is slightly smaller than the tile size and use the magnet system on the edges of the hole to fix the single tile
i can see the benefits of your bigger removable peice but say it was smaller tiles brick effect it wouldnt work do you know what im trying to say lol
yes its only as big as you want it you dont have to use the plaster board and yes i done it with brick tiles and even bricks slips
Perry
So there's no risk of a bath panel getting wet?
well i cant see how unless you you filled the bathroom up with water or stood there with a hose but most of it would run down the stairs i am not having a go at you just saying why use a product if it costs more when you dont need it its not a problem using it its better than plaster board but i always advise builders not to use backerboard on boxing only if its getting wet like a shower if its not use plasterboard imo
widler
1,328
England
completely right mate,if it gets wet,its down either to the tiling failing or plumbing through mostly bad workmanship.
ive been plastering and tiling for over 25 years,never had one fail on me,ever(apart from one where the walls were ply,not my doing)and i have only just started using tanking as well ;)
The Legend; Phil Hobson RIP
This one is completely removable the whole thing, on Hardie backer. Access needed to all areas under bath, Jacuzzi.
Reply to how to build a bath panel in the UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
Kitchen Tiling Guide This simple Kitchen Tiling Guide is something a lot of people could have...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
