Discuss How to deal with black mould on walls. in the UK Tiling Forum area at TilersForums.com.
Yeah, blown insulation mate. I know new builds dont use full fill and I have no real problem with that. To me however the cavity is there for a reason and it aint to fill it!!![/QUOTE]
It worked that way for donkeys years
could just be condesation ! have you a decent size radiator in the room ? as you need heat and ventalation to cure condensation. you could use bleach to get rid of the mold then use a diuhumidifier the take the moisture from the walls.
The bleach wont kill the mould completely and it will come back. If you have a shower then its building regs to have extraction in the room anyway. As for cavity wall insulation, did you have the mould before?
Id be suprised if the mould would penetrate the grout joints as i have tiled some pretty minging bathrooms and its not happened yet.
When did the mould 1st appear ? After the insulation or before? Is it in just one area ?
Reply to How to deal with black mould on walls. in the UK Tiling Forum area at TilersForums.com
