How to drive manually HT1621B LCD driver IC? Electrical Advice
How to drive manually HT1621B LCD driver IC? Discussion ThreadHow to drive manually HT1621B LCD driver IC? Electrical Advice
  • Im trying to figure out how to drive (manually-bitbang) a HT1621B LCD driver IC. It is capable of driving multiplexed LCDs. They are very cheap, but only in smd form, which is a bit of a challenge to solder all its tiny 48 pins. See youtu.be/xwRXpbxjLcw - you can skip through the movie since it's a long one. I actually managed to drive them using a special library in arduino, and they work beautifully but...I want manual drive. Why? because I can use only logic ICs like nand gates,multiplexers, FF's, etc 40 and 74 series, and also my favorite very easy to drive 12F508 PIC. And I can also add custom characters or shapes or symbols.
  • I read their datasheet a couple of times and STILL, I can not decipher the real way of driving them. I also find 2 AN's (AppNotes) AN2343-Cypress and AN0468e HT162x Application Guidelines -HOLTEK. They helped a little but not completely.
  • Here is a list with all my LCD movies I made so far: Q12 LCD - https://www.youtube.com/playlist?list=PL6NJF1kQFOAI0-AstwH5YHuOHenjLtkbS, including this HT1621B IC. Again, skip through their content since Im showing you what I tried and how high I could reach.
Thank you very much.
How to drive manually HT1621B LCD driver IC? for the original thread on Electricians Forums
Electrical Advice
Lou,
Lou,
