nice architrave cut very well done but you must agree you do get a better finish if you let the tile under the wood work and not all tilers do such nice cuts as you i have seen some right butchers
Cut the tile or cut the wood....hmm.
I still think it is quicker to cut the wood.
There have been a couple times when I didn't cut the wood due to having no saw, but by far the best is to undercut.
No Silicon and no grout at that point makes a really clean profile.
Is that a better perspective (wide view) What we can see is a fitted door matt to a back door fixed at 1m then hall carpet. A fixing bar between them. But the tiled floor meets them from the downstairs loo without a trim piece.
Yes it would have been better to have the doormat fit across the entire width of the door but it only comes in one size so is short.
I always cut the architrave and door stops away but NEVER the door frame/lining, a lot of door linings are either sunk into the screed or fixed to the floorboards, I know a lot of chippy's that do this to help secure the lining and if you cut it away you can loosen the whole frame.
