Discuss how to re instate the damp proof membrane in the Canada Tile Advice area at TilersForums.com.
merit
493
hi all
just ripping out a 1940s bathroom today, floor was tiled, got me breaker out and first one lifted no pobs,
no wonder it was stuck to vynal tiles on 20mm bitchumen.this bitchy is right the way through the ground floor,sounded hollow, so breaker again and come up in 3 ft squares, no adhesion to the oversite concrete at all, im aware this will have been used as a dpm, ive checked in the concrete and theres no poly in it at all.
what are the options for re instating the dpm, then prepping for tiling,i know there are liquid dpms but are there other routes to take cheers
Ajax123
1,213
Lincolnshire
I would go for a 2coat DPM system and broadcast sand into the second coat (dry sand) once set vac up any residual sand and you will have a great rough coat for bonding your tiles down to.
Ajax123
1,213
Lincolnshire
could i then just prime and slc, floors a bit out
Wouldnt think you'd need to prime for the sic on top of the epoxy/sand if you use a high polymer slc. Tremco and bostik both do slc's to go direct onto their DPM products.
Reply to how to re instate the damp proof membrane in the Canada Tile Advice area at TilersForums.com
Hi, I have a small roughly 1 metre square porch area that we would like to put tile down on and...
6K
My bathroom is on the ground floor of my circa 1900 end of terrace house in Sussex. It had lino...
34K
J Sid
Hello all, I seem to be in a dilemma with the tiler and tiling my bathroom. First of all...
17K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
