L
lower
We are in the process of restoring our 1920's house.
There is the original tiled floor in the hall which the previous owners had tiled over with an attempt at recreating the original Victorian style floor.
The overtiling was awful, so i've carefully removed the tiles to see what state the original floor is in and its actually pretty good. There are a few damaged tiles and an area of sinkage, but its near to the edge of the floor and some of the tiles are loose so i can easily lift them an re-lay them properly.
However, the tiles laid onto the original floor were laid with a cement type adhesive and there is a lot of adhesive that hasn't come up with the tiles.
Any suggestions on how best to remove this adhesive without damaging the tiles below? Scraping works but its a very, very slow process. I've tried steaming the adhesive which has worked with non cement type adhesive in the past but with no effect.
Can i use brick cleaning acid or will that damage the surface of the tiles? If not, can anyone suggest anything else that will make the removal process easier?
Thanks in advance.
Thanks in advance.
