Richard Edwards
Very interesting info on the acid.
Where i used it i found it to be very effective but i did rinse well a number of times and then washed the tiles with an alkaline propietry floor cleaner with the intention of neutralising any remaining acid.
I'm glad i've not caused any irreparable damage, and yes i did wear suitable PPE.
My tiles appear to have no grout between them at all. They are just butted together.
Is that normal? Any further advice as to how i can lift a tile in the sunk area?
I'm making steady progress cleaning the floor of the adhesive at the rate of approx 6-10 tiles per night. But i'm concerned that the sunk areas might be more than i can take on. I'm pretty handy on the diy front and have done plenty of amateur tiling that i've made a decent job of but i really don't want to end up ruining the floor and having to lift and re-lay the whole thing!
Hi Lower - sounds as it runs together !!
This is very difficult if it dropped and not loose enough to lift. You have two choices here.
1 Break a tile in the middle of the 'bad' patch with a hammer and work away from there. Being in mind that you will need to replace it of course.
2 If you have any sort of gap - even really small, insert a fine knife blade and start to apply a lifting prising action to each side of the tile alternately to get it to move.
I have made tools for this purpose from old kitchen / dinning knives and refashioned them on a grind stone ..
Normal PPE Precautions of course - especially eye wear
When completing the job suggest you regrout even if not much gap - We use Butec rapido cemento as its only 50 microns and sets in 3 hours.
