Discuss Hygrometer on Ebay in the Canada Tile Advice area at TilersForums.com.
another 4 coming, man you must have some tools, your garage must be like Aladdin 's cave !!!
Dont follow Balls written instructions on the unit.
Sand and area of floor and before sealing the unit to the floor make sure UFH is off and has been for at least three days. Seal to floor and leave for 24 hours. After that time turn on, leave for a further 24 hours and take the reading.
Before using the unit again leave a space of 24 hours and then repeat.
Thats my way anyway.
Pretty much spot on ... the only thing I will add is that the unit should not be left in place for more than 72 hours as the micro environment under it can cause interstitial condensation to form making the results very inaccurate. Not sure you need 24 hours before using the unit again but if it works then no argument.
I must admit I placce the box somewhere it wont get stood on or kicked but they say to use a protimeter to establish the dampest area of floor and place box there. I have used a simple moisture tester to establish this in the past. Do not place in draughty areas.Thanks guys.
What are the correct moisture levels to allow tiling and where is the best place to place the hygrometer.
Thanks again.
As far as I understand, 75% if you are using cement based addy, 85% if using Gysum based adddy. ,,,,,,,I can hear Alan galloping in as I type !
Reply to Hygrometer on Ebay in the Canada Tile Advice area at TilersForums.com
