i need a cheap wet bed cutter
might be too late, but i bought the 750w vitrex wet cutter from bnq for £100.00 about a week ago. done my flat ( bathroom, en suite, kitchen and bedroom with porcelain. 300x300 and 600x600 and worked really well. the cuts were brilliant. the only downside is that the screws that hold the gaurd down get in the way when you push the tile through so when it gets to the end of the gaurd u have to lift the tile over the screws and carry on which leaves the tile unsuported and sometimes snaps just about when u finished cutting the tile. and having to cut the little bit off that snapped.
but you can work around it and done the job for me.
although you will need a new blade fairly quick as mine went just as i finished luckily.
if you can't get a plasplugs(some b&q's still have some stock)then i would get the 750w vitrex,it's very similar:thumbsup:
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
