Bit late on the conversation but i too did the same once and like you re did the whole lot.Have made the mistake when I first started but removed them and redone it.
NonsenseHi all, it’s been a while but the dispute is still ongoing. They are now saying that they had to start with a full tile at the bath due to metro tile choice, is this correct? See their reply
We are of the belief that based on the tile selection being bevelled edged, that starting with a cut above the bath, would lead to a greater risk of water ingress as well as less aesthetically pleasing due to the Silicon line not being consistent.
Ask the client how to set the room out!
That’s why they are paying you - to do a professional job.
Clients away on holiday, that’s okay I’ll send him a photo of how it’s going to look - he’s going to be really confident in your ability.
What’s been done is sh*te and these chancers do our trade no favours.
AgreedNonsense
[automerge]1562962315[/automerge]Nonsense
They're wrong(lying) again. All transitions between walls and floors should be siliconed as per adhesive manufacturer instructions. Find out what adhesive and grout they used and you could get that in writing from them[automerge]1562962315[/automerge]
Thought so View attachment 108050
Regarding the vertical corner joints, they say.
Wickes Way of Working stipulates that grout is to be applied to all vertical joints as well as joints between wall and floor tiles etc.
Do you also know what size these corner joints should be as some areas are as small as 1 - 2mm?
