Guest viewing is limited
Discuss In need of advice screed/ slurry /tiles in the Australia Tiling Forum area at TilersForums.com.
sparx83
I own a small cider company in Northern ireland,
i am looking to have some Vitrified porcelain tiles installed, but from what i hear, i need to install them using a modified screed and a slurry coat and vibrate them in,
Has anyone any experience of this method?
what questions do i need to ask?
Thanks for all your help.
Ajax123
1,213
Lincolnshire
It's quite an old fashioned method. Similar to the old pressed wet bed method and similar to laying terrazzo. However, I'm not even sure it would work with porcs as they may be too brittle to withstand vibration. I would have thought with modern adhesives there would be a much easier option.
The Legend; Phil Hobson RIP
Sorry I just got a chance to reply, TJ is correct we did thousands of m2 using this method visqueen mesh 60mm semi-dry 4:1 screed, with OPC slurry,(monolithic) all laid in one.
Afright is right too ZinZig ( Buchtal).
Not sure about fixing porcelain this way, I think you would need to add polymer to OPC slurry. ZinZig are dust pressed so they will draw in the OPC slurry, but the low porosity of porcelain would need a polymer to bond imho.
Power vibro damn good method.
Would vibrating it break the porca phil ?
I knows its hard but its brittle as well, erm if you know what i mean :)
Don't think so Craig as the screed will give, we worked on boards as shown in the pics to spread the weight, we also wore snow shoes to walk on tiles when vibrating.
This method works better with small tiles, ie. 150mmx 150mm/ 100mmx 200mm/ 150mm octagons.
widler
1,328
England
Ah ok, i see, did not look at pics.
Nice one phil, hope you ok mate
Reply to In need of advice screed/ slurry /tiles in the Australia Tiling Forum area at TilersForums.com
got an 80m2 porcelain job upcoming ....seagrass carpet currently down on top of foam backed...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
