Indian Sandstone Picture Framing/Grout marks
Sorry both products are Lithofin - there’s a choice of cement away or builders clean.
I think the problem with this type of grout was as someone else said, it’s rapid setting. It maybe set on the slabs? Wasn’t washed off fast enough?
I managed to find one other thread similar from 2012 on another site. They replaced the slabs which hasn’t filled me with confidence & isn’t an option full stop
Cement away
I'd try Lithofin builders clean first on sandstone, try in a small area out the way first
Stop dissing my advice then.
Don’t see where I’m dissing your advice? If it’s just a case of you don’t like anyone else having an opinion on a thread then you are in the wrong place it’s a mirror you need. Just ignore me as I will you!
1sandyh,
Lou,
1sandyh,
Lou,
