Discuss inspection panels in baths... in the British & UK Tiling Forum area at TilersForums.com.
L
len
ok,ok...... it seems that the concesus of Have recentlyopinion is in favour of tiling panels ! I got to agree that a removable panel is fine. The problems come when the entire panel has to be removable. supporting framework has got to be substantial to counteract the tendency of plywood to bow. Last panel I used Wedi board...may have found the solution........
GazTech
Any cement based backerboard is perfect for this type of job,the 6mm type is easy to install and cut and very stable....Gaz
Are you remodeling your bathroom or kitchen? If so, chances are you'll need a moisture and mold resistant substitute for drywall, or a backerboard for your tile applications. You can trust HardieBacker™ Cement Board as your solution for wet area floors, walls, ceilings, and countertops because your home is your most important investment. Although no system is mold proof, HardieBacker™ board with exclusive Moldblock™ Technology delivers the ultimate in mold resistance, passing both industry mold tests with a perfect score. Whether you're hiring an installer to do remodeling work or buying a new home, be sure to ask for HardieBacker™ board by name. There are a number of alternatives on the market, but only HardieBacker™ board provides the greatest flexural and compressive strength available, while offering Moldblock Technology. You can rest assured that when choosing HardieBacker™ board, you’re taking a proactive role in preventing mold growth and moisture damage before it starts. HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology
HardieBacker™ 1/4'' Cement Board, with EZ Grid® Technology, for floors and countertops is America´s best selling 1/4'' board. It's the solution you can trust for your wet area floors, walls, ceilings, and countertops. This no-mesh board is the lightest cement board available and cuts easily, even in tight, awkward spaces,including bath panels.
Reply to inspection panels in baths... in the British & UK Tiling Forum area at TilersForums.com
Hi guys, sorry for long post, just after a bit of advice regarding my first proper complaint...
2 3
15K
Starting a bathroom Tues and the customer wants the existing plastic panel removing and tiling...
7K
How do I drill a hole in a steel bath. Or cast iron bath. Instructions on drilling into baths...
16K
Deleted member 1779
I have had a re-wire done and don't want to go to the expense of totally re-tiling the kitchen...
5K
Chrissyan
H
Hi All, Firstly I'm not a tiler! I've just moved in with my partner and I'm looking to rent out...
I
Tags
usa
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
