I
Ian
There have been a few threads recently asking questions about the correct procedure for overboarding wooden substrates with hardiebacker cement board. I did one earlier in the week and took a few photos, so hopefully this will help answer a few questions.
First things first, hardiebacker provides no extra structural strength to the substrate, any deflection MUST be rectified prior to its installation.
22mm chipboard substrate, hoovered and primed with SBR.
Boards cut to size using a carbide scoring tool, usually 3/4 deep scores are enough, then snap the board.
Boards are then stuck to the substrate using a SPF adhesive, some people have mentioned that a non flexible adhesive will suffice, I disagree, I think it is good practice to use SPF throughout an install on a wooden substrate.
A 4/6mm trowel is used to spread the adhesive.
Boards are laid in a brick bond fashion, and on larger floors can be laid in herring bone to shorten the joints. 2/3mm spacers are used to create an expansion gap.
Boards are screwed to the substrate while the adhesive is still wet, this install was hardiebacker 250 (6mm) so 25mm screws were used. Screws have been placed at 200mm centres, approximately 30 screws per 1200x800 board.
After sticking and screwing the boards, remove the spacers and tape the joints with an alkaline resistant tape.
You are now ready to tile!
Here is a link to the James Hardie web site for any additional information and safety advice http://www.jameshardie.co.uk/developer/products-backerboard-hardiebacker250.shtml
I hope this is of use to someone, if I have missed anything, let me know and I'll edit it in.
Cheers Bri.
Sent via Tapatalk for iPad
Cheers Bri.
