Discuss Insulation boards in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Don't forget there are two types of insulation though. The NMP may offer a better acoustic insulation value than the Ekoboard if it is more dense. Can' find density figures for the NMP though.
Ajax123
1,213
Lincolnshire
Similar - The Ekoboard seems to be XPS (Extruded Polystyrene) Lambda value 0.027 whereas Celotex is PIR (polyisocyanurate) Lambda Value 0.023. Celotex will offer slightly better thermal insulation mm for mm but I think the Ekoboard would probably be slightly more robust to mechanical damage.
richarevans1
throw this one at you with timber floors why not lay sisolation foil down on floor first then fix cementsheet over havent done it myself but have heard of others doing it might be worth a thought Insulation Foil
Won't you get condensation forming above the boards that way? I have a very cold suspended wooden floor I was looking at insulating, and the consensus on the various websites I looked at was that the insulation would have to go under the suspended floor to prevent condensation and rot. Which is why I haven't insulated it yet ;)
Gazzer
Well this is my reply from NMP
"The 6mm No More Ply has a Thermal Conductivity value of 0.412 W/mk to ISO 8302:1991 (BS EN12664: 2001).
The Beavaboard however is 0.027 W/mk to BS874.
Unfortunately thermal values are a minefield because there are differing standards, as here, and different ways of measuring them. However, in real life comparisons with cable underfloor heating the following approximate results were observed:
1. Onto bare concrete slab – took about 3 hours to reach max temp of 24°C.
2. Onto No More Ply 6mm – took about 40 minutes to reach 24°C and 3 hours to reach max temp of 27°C.
3. Onto Beavaboard 6mm – took about 30 minutes to reach 24°C; temperature 29°C at 3 hours and still increasing.
If you are going to use No More Ply under wire underfloor heating, you must remember to prime the surface with Mega® SBR as this helps to reflect the heat back up.
In summary No More Ply reduces warm-up time, increases efficiency and allows a greater maximum temperature. Beavaboard is cement-coated foam board of the same type as recommended by underfloor heating companies, and has the same effect but to a greater extent."
Gazzer
So.. How does SBR reflect heat,,:)
jay
prob right spose you will get the same with insulation board
Gazzer
if you dint have this insulation board then what are the other ways for under floor heating?
I really want to know because, we can warm the room with Ac but it dosn't effect the flooring, especially those chilled tiles.
Sorry can you rephrase this, not sure what you are saying ?
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping some threads in the underfloor heating forum. You can now find and search for both electric underfloor heating and water underfloor heating threads. By the way, if you feel some of the threads you want to be seen at the top of the forum need to be bumped back, for the next month or so from now, feel free to do that. Although it's not usually something we allow, whilst we're going through this process of changing over forum software, we see the need for this to happen.
Reply to Insulation boards in the UK Tiling Forum area at TilersForums.com
To Clean Out: Remove Old Glue, Mastic, Filler and Set Back to Studs? OR: to add Glue and Leave...
Looking for advice on how much adhesive to use. I’ve taken on my first tiling project and found...
Hi Everyone thanks for having me on the this forum ill try not to break any rules. I am diyer...
Insulation boards
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
