adgog
Hi guys,
Apologies in advance if this has been done before but I've had a look through the forums and can't find a great deal on this.
I'm re-tiling my bathroom. Two walls are external, tiles came off ok, down to plaster, filled in a few small patches, no major trauma. Two walls are plasterboard, old tiles came off easy enough but the old tile adhesive remained. This stuff is rock hard, I've tried scrapping it off but it isn't easy and seems a little unpractical to proceed with this given the surface area. So i popped into my local Topps today to get some advice, the guy suggested just tiling straight over it.... 'you can get away with a lot nowadays with modern adhesives' and all that kinda stuff. Initially I though that sounded pretty good but I'm a little uneasy about it. Is this ok to do? or should a really try to remove all the old adhesive? or even replace the plasterboard?
I'd really appreciate some advice as I'm just getting into tiling.
For info, these plasterboard walls are not where the bath is, the bath is on an external wall. I've got 300 by 400 ceramic tiles, was going to treat the walls with BAL primer and use bal single part flex.
Advice most welcome..
kind regards,
ad
kind regards,
ad
