Is this a bad tiling job or not?
I personally didn't know what the best option would be, I asked him to do the best job he could do and let me know if he thinks something should be done differently in order to achieve the best result. If he had advised to take the skirting off yes sure I would have gone for that.
Saves loads of cuts and means u don’t have those gaps
I would imagine if you gave any decent tiler the option of having the skirting removed they would jump at it, am I right in thinking that theee are multiple rooms all tiled throughout, this would be near in impossible to set out without cuts and as walls are never true u would always have diffrent cuts at each side at least with skirting off u wouldn’t have silly wee cuts , I’m a fan of the old box skirting as this gives (approx) 35mm cover all round , but even with your skirting still plenty of cove 12 mm mdf ripped to hieght with top mould feature fixed to 2x1 rails top and bottom , prepaint mdf and mould , always great finish
It’s a far better job IMO.
I tend to remove the skirting and replace after tiling but leave a small gap under the skirting so that when it’s painted you can slide newspaper under it.
Skirting should be prepainted and therefore only touch ups at corners , nailgun will busy brads if set to correct depth , like u said it also allows for movement due to underfloor heating and expansion
Depends on the paint. I’d prefer my painting to be done in one hit, not patched in over every nail hole and bit of filling. It would be primed beforehand though.
Tilers Community
ChrisC,
Spare Tool,
ChrisC,
Spare Tool,
