Issue cutting tile with sigma max
I have had some tiles that will not cut on a snap cutter, no matter what you do, years ago I was tiling a basement floor and was setting 8x8" (200mm) tiles.
The floor was over 600 square feet diagonal set, every single cut needed to be cut with a wet saw.
One thing you might try is to use less pressure to score and not ever score twice. The surface finish will also make a big difference, high gloss will cut better than rough (stone-slate) finish.
How long is that tile? You might need a bridge saw to cut them.
Hi. Thanks for replying to my thread. The tiles are only 600 x 300. Maybe my wheel is too low as some times when I just push the roller to score the tile breaks. Been hit and miss today with some nice cuts if scored a few times but also a lot of shearing.
As I have said before, there are some tiles that cannot be cut on a snap cutter, a wet diamond saw is the only way.
When I did my bathroom over in NJ USA I, I made sure I could make the cuts at the edge of the tiles. there was no way to make a square cut in the center of the tile, it would almost break the same way. and at $5.00 a tile I stopped after 5 tiles!
The cut around the light switch was a u cut with a piece!
Score lighter. Pressing on to hard can cause your issue. Then when you break the tile , hit the handle quickly. Shock breaking 👍
Been trying all things here. Even got the manual out which shows the bar around 3mm in the box from the top on the handle. Keeps breaking the tiles. The only times it actually works is when cutting a thin piece in half like 40mm. Having to cut all cuts with an angle grinder which is taking a loooooong time. Is there a place I could go and get this machine serviced? How often should the blade be replaced?
Thanks all.
Slow down as the score comes to the end to make sure it's scored nicely where it's coming off diagonally.
Where are you placing the breaker bar when you hit or press to snap?
See post 10 and 11, sometimes it is not the cutter, but the tile. Maybe you could take a piece to someone with a wet diamond saw and try a cut on it.
Some tiles seem to be very "stressed" if that is the word, and will not cut on a snap cutter no matter what you do.
Turns out it was the tiles. Got some feature wall tiles and they cut beautifully.
Thanks all for trying to help me on what was a lost cause.
On another note. I left my levelling clips in too long and some have broken leaving part in the grout line. Any idea on my options to get em out?
Thanks once again
Leroy Brown,
Leroy Brown,
Leroy Brown,
Leroy Brown,
