Issues with megger mft1720
  • Thread starter Thread starter slacky1230
  • Start date Start date
Hi
I've got a megger mft 1720 that I was hoping any one can shed any light on
When performing continuity tests (even when nulling the leads) and earth loop tests I seem to get higher readings than normal.
After a while of testing the tester seems to settle down and gives more accurate readings.
The tester has been calibrated a few months ago but has been like it for a while now. I've also brought a new set of leads in case they was the issue but still the same problem.
Has any one had any simular issues with their megger?
Continue reading...
Electrical Advice
Tags Tags
None
slacky1230,
slacky1230,
