Iv'e seen it all now....
  • Thread starter Thread starter DHTiling
  • Start date Start date
  • Tags Tags
    usa
DHTiling
[FONT=Arial, Helvetica, sans-serif]Our new system makes tiling easier than ever before. Using the Quik-Tile™ system you can be confident you will achieve a professional looking finish quickly, with the minimum of mess and no skill or previous experience required.[/FONT]
[FONT=Arial, Helvetica, sans-serif]We have a new kind of spacer designed to de-skill the process of tiling by spacing between tiles AND the tiles from the wall, a new solvent free specially formulated adhesive, unique multi beaded applicators to accurately metre the adhesive delivery, and the grout nozzle to help you finish off the job quickly and without mess: All four system components working together to help you to achieve a new level of tiling quality.[/FONT]
[FONT=Arial, Helvetica, sans-serif]Unique Adhesive Applicators[/FONT]
[FONT=Arial, Helvetica, sans-serif]The unique and patented Plasplugs Quik-Tile™ Multi-Bead Applicators deliver rapid-grab Fix’n Grout™ adhesive to each tile, rather than having to spread lots of adhesive across a wall.[/FONT]
[FONT=Arial, Helvetica, sans-serif]More consistent, Quik-Tile™ Applicators deliver a metred amount to each bead for a more controlled application with no mess[/FONT]
[FONT=Arial, Helvetica, sans-serif]Optimum Spacing[/FONT]
[FONT=Arial, Helvetica, sans-serif]Evenly spaced parallel adhesive beads automatically delivered for optimum coverage and economical use of adhesive.[/FONT]
[FONT=Arial, Helvetica, sans-serif]Improved Setting [/FONT]
[FONT=Arial, Helvetica, sans-serif]Beads spread when tile fixed but air channels maintained to assist adhesive curing.[/FONT]
[FONT=Arial, Helvetica, sans-serif]Four Adhesive Applicators[/FONT]
[FONT=Arial, Helvetica, sans-serif]To meet the varying needs of different tile sizes and projects, four sizes of adhesive applicators are included. Interchangeable, they can be cleaned after use.[/FONT]
[FONT=Arial, Helvetica, sans-serif]Rapid-Grab High Strength[/FONT]
[FONT=Arial, Helvetica, sans-serif]Anti-Mould Formula[/FONT]
[FONT=Arial, Helvetica, sans-serif]Solvent Free[/FONT]
[FONT=Arial, Helvetica, sans-serif]Grout Applicator[/FONT]
[FONT=Arial, Helvetica, sans-serif]For grouting tiles, using the [/FONT]
[FONT=Arial, Helvetica, sans-serif]Fix’n Grout™ Adhesive.[/FONT]
what ever next.....
would you use this or not..??
With the amount of professional tilers that use Plasplugs products, I feel the company should be ashamed of themselves!
None of what they are trying to do here would comply with british standards IMO!:mad2:
Grumpy
Seriously people will try to fix and grout tiles this way...there should be a law passed prohibiting it's use......Gaz
ive been using it for weeks now and only had 7 out of the 8 jobs fail! Result!!!
Obviously im joking, what a mare this stuff is. Maybea good idea to keep a count on here of how many jobs we go to where this stuff has actually failed eh!!!
I always thought the minimum coverage for wall tiles was 60% ??? this does not come close to 30%......
abskiing
hilarious!
so when you need to back butter and put addy on the wall to make the odd tile level,,just put massive blobs in the corner ...pmsl
no thanks ..
i'd rather try and plat sawdust!!
steve
Obviously this product is targeted at the very novice DIYer, I can see them now looking at it on the shelf at B&Q. He takes it home and says "right Margaret I'm going to tile our bathroom", three days later he calls a tiler, genius!, thankyou Plasplugs for your indirect marketing strategy in aid of all us pro tilers.
GOOD THINKING!
Tags Tags
usa
DHTiling,
brummie tiler,
DHTiling,
brummie tiler,
