mreeves
Looks like it is in the stone. Do you have more pics ?
More photos here (I did post these extra pic earlier but the post seems to have got stuck in moderation or something as it never appeared)
Discuss Jura limestone appears to be rusting over time in the British & UK Tiling Forum area at TilersForums.com.
How high is the humidity level in the house? Has the heat in the home been turned on? It appears to be iron in the stone rusting from moisture. It may be possible that the stone had not dried out enough before applying sealer. Some of the rust may be removed with Iron Out but as long as the home is humid it will return unless well sealed with a good penetrating sealer but after the surface rust is removed and the stone has dried out well.
You've lost me - did you mean to post this to a different thread?
No it is to you. You have a problem in your bathrooms I think you need to get the marmox rep out and show him the installation pictures and see what he thinks
Picture 149 and 150 from the start
Picture 18 has tiling on the wall and a section of exposed marmox with no washers on the screws if they did not use the washers the boards will not hold the stone to the wall so you will need to make absolutely sure this was done IMO they should be glued and screwed with washers.
Reply to Jura limestone appears to be rusting over time in the British & UK Tiling Forum area at TilersForums.com
