Discuss Jura limestone appears to be rusting over time in the British & UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
I agree its in the stone but there are more of these rusty spots appearing over time so keen to do something if possible to stop it happening further.
Im not sure there is anythingo be doe. Oxidation is a natural process.
Ajax123
1,213
Lincolnshire
Does the sealer not prevent it from "breathing".
Also if everything underneath is dry and the stone is dry why does it need to breathe.......
Just a little confused over this breathing lark cos modern buildings are simply not designed to do so.
DHTiling
If any moisture does come through a substrate , then if you use a topical sealer this can trap that said moisture in... when a substrate heats up and cools with room humidity or thermal heat, then as it heats and cools it can expel small amounts of moisture... Impregnators allows the stone to breath.. not literally breath lol but to allow passage of moisture from behind if required..
The best way to describe what i mean by air moisture etc,, say you left a pot of salt on the bench/table etc then it will get wet from air moisture..
So air moisture is always present ...
Not saying topical sealers cannot be used but in areas of wetting then deffo a bad idea..
Topshop
Thanks for the explaination Dave.
I agree with you Tony. But, the term "coat" needs to be used carefully. Sealers should not be coating anything - they should be in the stone (penetrating) for best results - if they coat they are sitting on top and have been over applied. Any excess should be buffed off because it can adversely effect the stone too. The term "application" should be used. If footprints show or the stone is sticky the sealer has been over applied.
Reply to Jura limestone appears to be rusting over time in the British & UK Tiling Forum area at TilersForums.com
Hi all, just after a bit of advice. I've just had some 15mm limestone tiles fitted in my...
Hi, Limestone tile floor installed at the beginning of December 17. The floor wasn't sealed as...
5K
Hello all, A friend of mine has a wet room tiled with grey limestone and is having a problem...
Rizzle from the Portizzle
I am a customer not a tiler! My architect wants to lay limestone tiles directly on to the...
7K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
