Discuss Just used 365 drills for the first time in the UK Tiling Forum area at TilersForums.com.
Mark B
Hello,
I have just used the 365 drill bits for the first time on a job with very hard full bodied porcelain tiles and they worked superbly.
The hole sizes ranged from 8mm to 50mm in fixed and un-fixed tiles and every hole was spot on, even when cutting crescents from the edges of tiles. The 8mm bit has cut 24 holes now and it's still going strong!
The only problem I encountered (as others have experienced) is that the yellow guide plate wears after only a few holes. I ended up drilling a whole load of other 8mm holes in it and used them.
All in all a great product :thumbsup:
Mark
Mark B
Yes they are well worth the money,why dont you put a wet sponge under the drill bit when starting off and once you have a start take the guide away and it will last longer.:grin:
Thanks for the tip. I have only been using them as instructed - dry to start for 10 seconds and then wet to complete. I found that it was still wearing the guide but I guess that's possibly due to the number of holes I've managed to get out of one 8mm bit so far. :yes:
Mark
Deleted member 1779
We often do the demos at trade shows.
I think the drills are lasting a lot longer than we claim!
The advice is to remove the plate after a few seconds but I am sure our diamond crowns are lasting for longer !!!
Certainly not getting any complaints about the drills...
And they work in the hardest of porcleain tiles.
Mark B
Hi Richard,
I'm using them exactly as instructed - the wearing of the guide plate is purely down to the number of holes drilled!
I've used the 6mm bit now and have found that the geared chuck in my Dewalt drill has crushed the bit. Luckily it's still centered so isn't causing any problems. Is this a known issue?
Mark
Reply to Just used 365 drills for the first time in the UK Tiling Forum area at TilersForums.com
Hi guys, Hope you are all having a fantastic Xmas. To cut a long story short I have installed...
  • Sticky
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
