Guest viewing limit reached
Just used 365 drills for the first time
We often do the demos at trade shows.
I think the drills are lasting a lot longer than we claim!
The advice is to remove the plate after a few seconds but I am sure our diamond crowns are lasting for longer !!!
Certainly not getting any complaints about the drills...
And they work in the hardest of porcleain tiles.
Hi Richard,
I'm using them exactly as instructed - the wearing of the guide plate is purely down to the number of holes drilled!
I've used the 6mm bit now and have found that the geared chuck in my Dewalt drill has crushed the bit. Luckily it's still centered so isn't causing any problems. Is this a known issue?
Mark
Let us know how you get on....
If you need the install team to do a demo then we can send them
Just make them a cup of tea!
6mm (quad pack) 8mm (quad pack) 10mm, 12mm, 14mm, 16mm, 18mm, 20mm, 22mm, 25mm, 28mm, 30mm, 32mm, 35mm, 38mm, 40mm, 42mm, 45mm, 48mm, 50mm, 53mm, 55mm, 60mm, 65mm, 70mm, 75mm, 80mm, 85mm, 90mm, 95mm, 100mm, 105mm, 110mm, 115mm, 120mm, 125mm
Above well thats our size range. I can also make any size in between as a special for you. For example in the past I have made and supplied 7mm, 11mm, 14mm and have some left in stock. We can work within a 1mm tolerance. Minimum spend for a special is £250.
I second all the comments on how superb theses drills are. I bought the basic set and have used the 16mm and 40mm so far, a few times. They are superb. Very easy to get started and very easy to cut all the way through on porcelain.
I'd previously used another make of drill, which had a flat tip to it - for porcelain. I managed to melt it before I'd even drilled half a hole - what a waste of £18.
However - these 365's are superb.
Thanks guys.
Paul
i recently bought the 365 drill set also,,ive been trying a few differnt makes out recently and the 365 set was very good on hard porcelain also.:thumbsup:
Seems like a good price for your drills ....do you sell a water feed system for them ? ....if so, that would save me a few quid on the de-walt ones I normally use !!!!
Mark B,
Dan,
Mark B,
Dan,
