Matthew77
Hi all.
Could really do with a bit of help from you more experienced tilers with pricing up this job & tile quantities?
Tiles are all 100mm x 100mm
Customer wants a feature above the cooker all white tile with 2 black strips of black tile running vertically from top to bottom. cooker & cooker hood area 1.2 x 1.4 (1.7m²) (I've worked out this area to be 2m² white tiles)
Splashback area 8.2 metres long x 400mm high (4 tiles high). Starting vertically with a black tile off the worktop then 2 white tiles then a black tile finishing off at the top running all the way around the length of the worktops. (2m² white tiles) (2m² black tiles)
Then there is the window reveals & sill to tile length of the sill is 1.2m And the sill and reveal depths are 200mm matching the same height as the rest of the tiles at 400mm high. Also there are 9 electric sockets to tile around.
Usually I work on sites at a day rate & I'm supplied with the tiles so I've not done alot of pricing up. I'm guessing that it will take me between 2 & 2 & a half days to tile & grout. The average meter rate here is around £25 m² for ceramic tiles but with the window reveal sockets & use of 2 different tiles I'm thinking that I'd be losing money if I priced it by the meter?
Any help would be really appreciated
