kitchen splash
charlie1
hi all,
I'm doing a splash back in a couple of weeks with those ugly small 100x100 tiles with wavy edges.
2 problems are the customer wants a random pattern using 3 different colours , how can you really do a random pattern without using too much of the one colour in one area, and how do you space these tiles out correctly when they dont have straight edges? I assume you just do it by eye.
Mark
Set out a pattern before and ask the customer for their approval. Do this throughout he job then they cant complain
i putthree piles of tiles in front of me and take one from each in a seperate pile. i then keep doing the same but pick them up in different order. just make sure you use the same amount of tiles and it gives a totally random pattern and makes sure you are using the same amont of each colour
As long as you try not to get clumps of one colour together then you will be fine...
if you are unable to use spacers, then you will have space them by eye....good luck mate....
I did a splashback a while ago using tiles like these sound, only they were all black, but had wonkey edges, and they are really easy to fit, just by eye, and space evenly.
If you cant use spacers use a screwdriver to poke between the tile spaces to give you a rough idea and obviously use your eye. Once grouted will look fine.
I actually liked the look of them more than the same old boring 2-3 mil straight lines everywhere.
The customer is just wantinng them tiles straight and a random pattern but i would like to do a decorative feature above her hob. if the tiles where straight i wouldnt think twice about it but ive never done anything like that with these tiles before. it could be a bit tricky eah.
u have to do it by eye..
watch your spacing some people end up with very wide grout lines..
calvy :beer_yum:
Let the customer lay out the tiles to their satisfaction.They just love to get involved.....then give them the tools :grin:
i done two kitchens last week with these tiles just space by eye look great when grouted and i had three colours just alternate two colours each row then repeat on third row easy......
I do alot of work for a local kitchen company who use 4" X 4" porcelein about 11mm thick and really heavy so I have to use spacers and move them so the tile looks square. I also draw loads of lines where i want the tiles cos its so easy to drift up or down with them.
kitchen splash
charlie1,
surflaur,
charlie1,
surflaur,
