Discuss Lash clips and riamonde levelling systems in the UK Tiling Forum area at TilersForums.com.
Anybody used the riamonde levelling system,I have used the lash clip ones but it hurts your fingers after a while,thinking of going the painless way,or do I stick to doing it without either to keep the cost down as you can spend £30/£60 a standard size bathroom,for the clips
Thanks for the response guys,to what extent do you get the substrate on walls and floors spot on,if your tiling a job for a builder or plumber where you're tiling a bathroom and the walls have dips and bellies as such or a floor with the same,as I put my level on the wall to see where I'm going to need to put more adhesive.
from your responses you both seem to have gone back to where you were before you tried them,which is exactly what I'll be doing,as I also find it expensive and more time consuming having to clean off the dried adhesive,as it's easy to clean as you go with standard spacers,cheers Darren.
Reply to Lash clips and riamonde levelling systems in the UK Tiling Forum area at TilersForums.com
Hi, yes I know the title sounds off Doh! lol Well to all you guys that have installed large...
45K
So... have a problem maybe some of you guys (and girls) might be able to help with. Laid a new...
19K
X
Hi I'm new on here and just had my floor tiled with 80x80 porcelin tiles. I knew it was a hard...
14K
L
There have been a few post about different levelling systems recently. Read 'em, intrigued by...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
